15 Bing
Christian Parks /
I have a new 15 bing and rebuilt e-50 engine which has good spark. Fuel is flowing to the carb. If I spray some starter fluid in the spark plug hole, it starts for a second. Cleaned the carb but when I remove the spark plug, there is no fuel on it.
Any suggestions?
Re: 15 Bing
Christian Parks /
The carb is not a clone.
Re: 15 Bing
roots to wings /
do the points open and close to the right gap?
Re: 15 Bing
up shits creek /
Float or float needle would be my guess.
Re: 15 Bing
When ya have the bowl off the carb and the gas line on does the fuel flow out the needle when float is down?
Re: 15 Bing
Probably Fred /
Is vent hole in the carburetor unblocked?
Re: 15 Bing
Christian Parks /
The points are properly gapped. I will check the fuel flow with the bowl removed. There was gas in the float bowl when I took it apart.
It is a new carburetor. I will have to look for the vent hole. I am not sure where that is.
Thank you
