Re: Blowing brake light bulbs
b to the eff /
A '78 hobbit doesn't have a regulator, just a rectifier.
That said, something is definitely wrong if you're blowing bulbs on a completely stock setup.
Replacing your bulbs with LEDs will result in more current going through the remaining non-LED bulbs, without a regulator. That said, LED bulbs are awesome and much brighter, so I recommend them, just get one of these too: https://www.treatland.tv/economy-6-volt-voltage-regulator-p/6v-voltage-regulator-economy.htm
