Re: Crank seals
Probably Fred /
Depends on the bike but if it’s a Engine that has a transmission then it will burn transmission oil on that side making white smoke or more smoke that’s different then two cycle oil smoke
And on the magneto side you could have an air leak, many times you could take the magneto cover off and you’ll see oil in magneto cover or covering coils whatever from the two cycle oil in the mix,
But either case you need to do a leak down test to pressurize in the intake and see where air comes out but not too or you blow the seal out
This almost looks like he’s operating a seal making machine ha ha
