Re: Dumb question but....
Aaron Blair /
Any single wire condenser with a mounting/grounding strap will work as an external condenser. Use the strap to mount/ground it anywhere on the frame with good conductivity and connect the wire anywhere between the points wire that exits the stator and the ht coil(what the plug wire comes out of).
