90s Ducati cdi box/HT coil combos. Anyone have a pinout?
Terbo Speghetti /
I've got a bike that has good spark, looks like an unmolested stock 90s euro wiring harness.
The Ducati box has three of four leads connected and I'm wondering why/how/who/what/when/where? The missing wire is white (blanco) if that solves it for someone.
The box is identical to these:
https://www.treatland.tv/DUCATI-cdi-box-for-minarelli-garelli-and-many-more-p/minarelli-cdi-box-three-wire.htm
Re: 90s Ducati cdi box/HT coil combos. Anyone have a pinout?
Terbo Speghetti /
The bottom one is a kill switch and the green wire is a fixed ground, but what purpose do the red green and white serve respectively? Is it common for these to just not have a white wire hooked up? (edited)
Dirty30 Dillon /
You've got most of it, green spade is for stator side ground. IIRC, Red is for power from coil, white is trigger (where applicable, a la the Vespa CDI).
In the case that the stock CDI stator doesn't have a trigger, than you can use just the power and it works like the kinetic style field-sensing and should trigger that way.
