Malaguti new dribbling turn signal relay?
Terbo Speghetti /
So I've got this euro spec malaguti new dribbling with a CDI and turn signals and all that other 90s stuff.
I'm tryna replace the broken turn signals with LEDs that I have on a shelf, but that means swapping the flasher relay for an LED compatible jobber.
Problem is, I can't find the original! It seems like the power comes out of a regulator/rectifier and goes straight to the turn signals but I know that can't be true because they blinked (blunk?) before.
Anyone else have one of these and know where I should be looking?
Re: Malaguti new dribbling turn signal relay?
Dirty30 Dillon /
Fuck, it's been a couple years since I worked on the Euro New Dribbling, but I seem t recall that the flasher unit was either under the center covers (hovering over the motor) or it's under the downtube cowl cover. I don't believe it was behind the headlight, but I honestly didn't have to mess with the flashers on that bike before I sold it.
Terbo Speghetti /
I've got the middle cover and the tank off, but the only things I've found are that reg/rectifier looking thing and the CDI box/HT coil on the other side.
Nothing behind the lights, nothing under the seat, nothing tucked up in the subframe.
The only thing I can possibly come up with is that reg/rectifier has a blinker in it somewhere. Sounds crazy but I guess it is Italian
I see the purple going back down to the rest of the bike, where does that go?
Terbo Speghetti /
There's a green and a purple that run back to the rear turn signals too, guess I left that out. Nothing between them and the switch tho. (edited)
Odd. My money is on some weird relay setup in the rectifier/regulator
