Re: Piaggio Si rebuild
Igor Egorov /
I will look at the steering wheel using your advice.
I never figured out the length of the belt. The pulley is 95 mm long; the old belt has a length of 1140 mm. The link for this pulley must be another belt https://www.treatland.tv/vespa-piaggio-single-speed-drive-belt-p/vespa-stock-belt.htm
What do you advise?
