Finally looked at the Magnum with no spark
Got this Magnum a few months ago have had a couple of health issues finally got to look at it tonight. It has zero spark. After looking closely at the terminal block. I can see that the blue wire coming from the ignition is broken off and not connected. Does anyone know where it goes in the block? As usual I appreciate your help.
Rob
Re: Finally looked at the Magnum with no spark
Robert Bentzel /
It seems kind of common sense to connect it to the Blue terminal block the second down. Not knowing where it came from I don't want to in short circuit anything it is the blue wire coming off of the coil pack by the way.
I believe that the dark blue cable goes into the 3rd terminal where the black one is.
https://www.mopedarmy.com/w/images/b/bd/1978_Puch_Magnum_XK_Wiring_Diagram.pdf
In this diagram it has a blue cable going into the same terminal. Also I wired a magnum today and they were connected without me touching it.
If you follow the spark plug wire, it should lead to a black plastic-looking thing called the high tension coil. That coil should have two more wires coming out of it — one is usually brown and goes to ground, and the other is usually blue and goes to the terminal block, where it connects to the blue wire from the stator.
♣Slew Foot♣ /
Blue black can be a taillight return ground...
Run the blue wire from the magneto to ground, see if that solves the spark issue. The worst that could happen trying things is grounding a wire that isn't supposed to, but that's the same as a kill switch--no harm, no foul. Sorry to hear that you've been ill but are back at it!
Blue goes to black on the block.
They always disconnect the blue wire in the movies.
