Re: vespa/piaggio si front variator stuck
Dirty30 Dillon /
Dremel down the length of the variator bushing, cold chisel to split it.
At this point your crank is more than likely toast anyways, so even just cutting the crank off with an oscillating cut-off tool would probably be wiser.
