worn rings? soft seize?
hello! a friend recently purchased his first moped, a 70cc general 5 star. i’m not sure how many miles are on the kit, but he said he rode around for a few hours, and it started losing power, to the point of eventually dying. the next day, the same thing happened in a matter of about ten minutes. he would wait a few minutes, then start the bike again successfully only to have it happen again. no air leaks, no play in the crank arm, pretty crispy beige-ish plug. no oil injection on the bike. the owner prior to him had the oil/gas mixture pretty rich, so we dumped the tank, and put the proper mixture in. also, the person he bought it from had things very loose (intake & exhaust, namely), you think the air leaks there could have caused a soft seize to contribute to the piston/cylinder condition?
it seems to me like worn piston rings, so i took some photos and was hoping for some input, whether he needs new rings, a new cylinder(?) or something else i may have been overlooking, before he purchases anything. the blow back beneath the top ring makes me think i’m correct, but in my 14 years of riding, i’ve never had a kit long enough to replace the rings, so i wasn’t sure.
thanks in advance!
Re: worn rings? soft seize?
Both, and loose intake is an air leak.
Probably Fred /
Not timed/tuned correctly! High timing = high heat even if kit was installed and jetted correctly. Nowadays people run a head temp gauge on kitted bikes to help tune and watch temp so they don’t get into the seize zone.
i also thought that, but before this bike was bought by this dude, it was purchased from a moped shop here in portland, completely rebuilt, with some boss ass b-words tuning and timing it.
a different moped nerd homie mentioned that it could be the condenser getting heat soaked and killing the engine power but i don't knowwwwwwwww. is that a timing/tuning issue? or just a bad condenser?
Your cylinder piston tore up
