OK GUYS, as promised see the attached photos. First of my makeshift setup as i work on the bike.
So you will notice that i hooked up black wire from the generator to the ignition coil, mounted the condenser to the ignition coil, and ran ground to the engine frame. I now realize this is wrong. I drew a diagram to make it easier to see.
You will notice that i did not wire the black wire out of the engine to the condenser but only to the ignition coil. After reviewing your comments, i see that i must do the following
You will note that i am intending on splitting the connection off the black wire that is coming out of the engine to go to the condenser and to the ignition coil, whilst still grounding the ignition coil. Please let me know if this is right or wrong. or do i run everything through the condenser first and then have that lead into the ignition coil?
I know totally newb question, but that is why i am here.
