Re: sachs pedal crank clearance with flywheel cover
Marc Friedman /
Take the crank arm off and bend it away. Don't do it with the crank arm on the pedal shaft. Put a dowel under the pedal shaft when you hammer out the bolt and wedge holding the arm o to the shaft. Loosen up the nut and whack the nut and not the pin.
