Your moped was probably droped on that side and bent the pedal arm..about the only true fix is straighten the arm or get a replacement. If you try to straighten it be careful ,they will break the pedal shaft off and cause a major problem
Subject | Written By | Posted |
sachs pedal crank clearance with flywheel coverTopic by: Eli Szymanowski | Eli Szymanowski | 05/17/21 11:00AM |
Re: sachs pedal crank clearance with flywheel coverRe: K Olena | K Olena | 05/17/21 11:03AM |
Re: sachs pedal crank clearance with flywheel coverRe: P D | P D | 05/17/21 11:05AM |
Re: sachs pedal crank clearance with flywheel coverRe: pat splat | pat splat | 05/17/21 11:33AM |
Re: sachs pedal crank clearance with flywheel coverRe: Pops Peds | Pops Peds | 05/17/21 12:52PM |
Re: sachs pedal crank clearance with flywheel coverRe: Marc Friedman | Marc Friedman | 05/17/21 01:45PM |
