Re: 1985 Honda Spree Oil in Bottom End, Starter or Battery Issue
punkrock randy /
Invest in a digital multimeter if you intend on working with anything electrical. Check your battery voltage with the meter. Set to VDC, voltage DC setting. It should be near 12VDC with the scooter off. Also make sure all of your connections are clean and tight. And make sure the battery’s distilled water levels are good. But it sounds like it’s cranking over so the starter is doing it’s job. Have you checked to make sure oil’s not way overfilled in crankcase? Check hondaspree.net for good info on these. (edited)
