Hi,
I'm having trouble with my Tomos I'm restoring.
I'm getting no spark at all.
This ped has been messed about with in the past, there's no loom so I'm working from scratch.
I hope I'm correct in using the black wire from the stator straight to the coil. Do I need anything else?
The coil is tested and works fine, plug is new.
I've attached the stator, it's the Ikras 12v 50w. The wiring has been played with, is it correct? (I've moved the windings back so you can see better)
The condenser is new, but it could be faulty? I have one from my mini i could use, but it would have to be external, where would I put it?
Sorry for an awful first post, I'm getting my hair off with it
