Nc50 crank bearings
just installed a new set of bearings on a treats stuffy crank. Heated the case bearings won't go. So I messured 2mm differince in bearing od. and case Id. any sugetions?
Re: Nc50 crank bearings
* the bearing outer race is 2mm bigger than case Id.
Wrong bearings. Measure your old ones. I'd contact treats to see if the crank is even correct.
The right crank wrong bearings. Looking for the right size though. They sent me 6004 c-3's
Jack Rutherford /
those sound like the right bearings - freeze the bearings and heat the case (edited)
> case
It wont make up 2mm difference. Somethings wrong.
Potential interference fit will be between −0.001 mm and −0.042 mm NOT 2.0 MM (edited)
Jack Rutherford /
6004 c-3's Have worked for me several times. Maybe there’s not a 2mm difference.
> difference.
Bearings could be wrong size Chinese junk.
