Re: Tomos A3 Not Running - Timing?
Jesse Nordlander /
Those have a goofy, and weak flywheel pin. Mount an external condenser on coil mount and tie it in to hot side. Should have a thick bright blue spark. As pat said, that mag seal Is a common issue.
It should have fired with fuel in cylinder anyway. Is plug getting wet while cranking?
