I would start by lubing up the threads on the gear puller with some light weight oil. Some penetrating oil around center of gear might help. Its a tapered shaft that the gear is mounted on so they are difficult to remove. Keep in mind that is a cast iron gear and can break. If you insist on using heat keep it away from the shaft otherwise the heat will expand the shaft and lend you no advantage. (edited)
