Re: '76 Garelli Super Sport Won't Idle
Aaron Dacanay /
Sweet thanks so much guys! I'll tell my friend to get this SAE 30 Non-Detergent I saw on Orielly's website, and to get some seals. We'll go ahead and get new crank seals, maybe an entire gasket, or seal kit. I also should've mentioned that the top throttle slide adjuster rubber piece that goes over it broke and is no longer on it. Is that a potential spot for an air leak? I heard it was an air leak spot on another motorcycle I have, so maybe it's the same with the Garelli's carb? I also installed a new o-ring seal on the fuel inlet on the carb (doesn't leak fuel now, it used to).
