Re: Ninja pipe leaking in weird spot
P D /
> Garrett The Kid Wrote:
> > Aaron Blair Wrote:
> > I repacked mine with steel wool and drilled a teeny tiny drain hole.
> Not
> > a problem.
> I’ve heard steel wool can be sucked back into the pipe and cylinder, but
> also never tested it myself so idk.
Copper or brass wool is a better choice .
Steel wool can rust and come apart pretty easily . Not so with the aforementioned .
Plus , copper or brass wool can be rinsed with gas and reused .
As for getting back into the motor , it's never happened that I've ever experienced , heard of or read about . I've been running 2 strokes way before you were born ( early 1960s to be more precise ) . ;)
