Noob here- I’m restoring an mb5 nearly from scratch. I can’t seem to find out if the two rings are identical. There are no markings.
Mb5 rings
Re: Mb5 rings
you measure them with calipers.
Re: Mb5 rings
What I meant to ask was- are they supposed to be the same/ can I put either one on top for example. I know there’s an expander under the lower ring. I also can’t tell if there’s an up or down side to each ring
Re: Mb5 rings
One ring is narrower , inside to out .
That goes over the expander , in the bottom landing .
Check for a slight bevel , inside to out . That goes up .
