Do I need to drain Hobbit gear oil when changing rear tire?
I just put on a new tire and tube a few weeks ago, and also changed the gear oil. Got another flat today. If I keep the wheel pulley side down on top of a 5 gallon bucket, will gear oil leak out inside the wheel or is there not enough in there to worry about?
Re: Do I need to drain Hobbit gear oil when changing rear tire?
be careful theres 5.5 gallons in the rear gear
> pat splat Wrote:
> be careful there's 5.5 gallons in the rear gear
That's funny.
You should be fine, had mine on it's side before and no leakage.
Terbo Speghetti /
If it leaks, drain it, install a new gasket and fill it back up.
If it doesn't leak, pretend it doesn't exist
Beach Club Nick /
If you like hold it upside down it will leak out. Otherwise it's fine
Thanks for replies, I usually drain/refill it when I get a flat every few years, this is the first time I've had 2 flats in one month and I used my last crush washer last time.
Anneal the crush washer and use it again . ;)
