I have a low mileage V1 that had a starter clutch plate bearing issue. I replaced the starter clutch plate. Also, replaced the chain on the moped. It started up fine but was hearing a clunking noise. Thought maybe the rear wheel wasn’t even and chain was slipping. Adjusted the wheel but still heard the noise periodically. It drove for a little bit then wouldn’t move. The rear tire spins on the stand, but won’t go anywhere. Does it sound like a clutch issue? Hopefully tomorrow I’ll get a chance to drain it and open it up. Thank you
