Re: Stumped by a damn bing!
Graham Motzing /
There is a tiny little thimble looking filter in the banjo bolt, it doesn't need to be lined up to anything. Also the banjo spigot nipple thingy can corrode closed, I had that happen a few years ago and messed me up.
If you want to test it, leave the bowl off and install everything else as normal, see if gas pisses out.
If you are stuck running ethanol gas, start adding some stabil marine in there.
