Is this a possible mating?
Tomos Targa forks on Vespa Ciao
Re: Tomos Targa forks on Vespa Ciao
I'm not sure the offspring would be viable
Like, the basic stock springer targar forks? The ones that are hyper prone to bending?
They don't/won't simply bolt on. The steer tube is too short on the Tomos frames. You're better off just putting on bravo/grande forks for the same effect and not having to do anything besides swap some bearing races.
Any fancy bicycle shop that does forks will have a facet/reamer tool for 25.5mm that they can remove some of the head tube of your frame. Then all you have to do is buy a set of Vespa headset and puch headset stuff and make some spacers maybe. Not hard but if you botch it, the bike is ruined.
tomos forks blow, I have so many and they're all trash
These are pretty https://www.mopedarmy.com/forums/read.php?2,4438736
Agreed. They will bend stopping too hard. Ha!
