hey all, i was dissembling and cleaning the throttle and i ended up damaging the throttle return spring, curious is that is really needed or will the carb be enough to return the throttle when tensioned?
maybe a picture might help, i dont remember there being a spring on a garelli, but if the cable is smooth like butter the sha spring should be able to pull it back w a little help.
my memory fading, too much gas, you probably has the spring spinning the wrong way. Dont garellis have that nice waffle grip?
