Re: Mobylette 50V Starting Issues
Ron Kujawa /
I'd definitely go back to getting spark first. Especially if you had it already. Double check that the kill switch is in the on position, or bypass it.
I would temporarily disconnect the choke. If you have spark and fuel, you should be able to get it to fire. Once you do, you can go back getting the choke working right.
I just got my 50V a month ago and it took every ounce of energy I had to get it to start by pedaling on the stand. Once I tore everything apart to install new bearings and seals, I discovered the starter clutch and drive clutch were a rusted mess. After seeing how bad it was, I was amazed I was able to get it to run before addressing.
You can also run a drill on your magneto to make troubleshooting and getting it started a lot easier. I'd stay away from an impact gun though. Use a drill, start slow, and use the decomp lever/valve. Begin with the decomp lever engaged to make it easier to turn the engine and once it feels like it wants to fire, let it go.
In my case, I needed to choke the Gurtner carb with my thumb while spinning the engine with the drill. It took cleaning and setting the float to get it idle and run decently. I did end up getting a Dellorto clone though, which has been better. (edited)
  Mobylette 50V Starting IssuesTopic by: Nicholas Conte Nicholas Conte 12/20/20 02:53PM
  Re: Mobylette 50V Starting IssuesRe: Richard Eberline Richard Eberline 12/20/20 08:20PM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 12/20/20 08:53PM
  Re: Mobylette 50V Starting IssuesRe: Ron Kujawa Ron Kujawa 12/20/20 09:09PM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 12/20/20 09:35PM
  Re: Mobylette 50V Starting IssuesRe: Ron Kujawa Ron Kujawa 12/20/20 10:29PM
  Re: Mobylette 50V Starting IssuesRe: Richard Eberline Richard Eberline 12/21/20 07:54PM
  Re: Mobylette 50V Starting IssuesRe: Satan 666 Satan 666 12/20/20 10:47PM
  Re: Mobylette 50V Starting IssuesRe: Rebel Moby Rebel Moby 12/20/20 11:07PM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 12/21/20 06:28AM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 12/21/20 06:32AM
  Re: Mobylette 50V Starting IssuesRe: Richard Eberline Richard Eberline 12/21/20 07:16AM
  Re: Mobylette 50V Starting IssuesRe: Aaron Blair Aaron Blair 12/21/20 11:50AM
  Re: Mobylette 50V Starting IssuesRe: Richard Eberline Richard Eberline 12/21/20 08:00PM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 12/22/20 08:50AM
  Re: Mobylette 50V Starting IssuesRe: Stephen Keller Stephen Keller 12/24/20 12:04AM
  Re: Mobylette 50V Starting IssuesRe: Aaron Blair Aaron Blair 12/22/20 01:15PM
  Re: Mobylette 50V Starting IssuesRe: pat splat pat splat 12/24/20 01:02AM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 12/24/20 07:04AM
  Re: Mobylette 50V Starting IssuesRe: Stephen Keller Stephen Keller 12/25/20 12:29AM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 01/21/21 11:08AM
  Re: Mobylette 50V Starting IssuesRe: Stephen Keller Stephen Keller 01/30/21 07:05PM
  Re: Mobylette 50V Starting IssuesRe: Gen Xer Gen Xer 12/27/20 11:41PM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 01/21/21 06:12PM
  Re: Mobylette 50V Starting IssuesRe: P D P D 01/21/21 07:19PM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 01/21/21 07:47PM
  Re: Mobylette 50V Starting IssuesRe: Aaron Blair Aaron Blair 01/21/21 11:18PM
  Re: Mobylette 50V Starting IssuesRe: Nicholas Conte Nicholas Conte 01/22/21 05:45AM
