Motto guzzi engine replacement
I’m considering purchasing a motto guzzi but it has no engine any direct fit that is not its original Benelli g2? They seem hard to find.
Re: Motto guzzi engine replacement
Anything else is going to require modification/ fabrication.... nothing too crazy tho just a little hacking and welding...
You may be able to design a bracket that can adapt a motor to the original mounting locations as well
There's a dude in maryland that put an a35 on his robin. IIRC he said it was pretty close. Still needed some fab work.
Definitely worth drooling over
if you read this the moped is now $35
Coupon code: 6feet
