Rosario, brand new spark plug, good spark Gap is correct took the carb apart looks clean main jet good,,,,,could it be something like points or ignition wiring mal functiond
Always : Compression first . Then timing . Carb last .
The carb has very small passages that can easily clog . Every jet and passage has to be pristine from entry point to where it exits .
Verify that with brake cleaner and compressed air .
