QT50 with fresh engine cutting out
So I went for my first longer(only went on 2 miles due to this issue) ride this morning.
So I’m about a mile into it and at mid throttle, running good. I hear this sound naaaah followed by a light non breaking pop, bikes dead. So I pull over, give her some throttle and she fires back up, I did this every 1/4 mile headed back home. It’s like I’m fuel starving it or something. I don’t know.
Re: QT50 with fresh engine cutting out
Check for seizure .
I think your forks are on backwards
The forks are on backwards, I did it on purpose, long story. When my powder coat guy gets things done that will change. But for now I needed a brake and didn’t want to argue with the tool store people about the expensive snap ring players I bought that broke first use.
I found a 77.5 main I’m going to swap for the 70 that’s in it now. I’m also going to install a choke and an oem Mikuni(in place of Minky) and see what don’t happen. I do have better exhaust, clean polished ports and new performance reeds in it now. May need a bit more fuel.
Just seems like a better situation. Fresh Yamaha gaskets, actual Mikuni jets. A choke, so no free flow or leaks.
Seems to run fine now.
Alright put a new(fresh rebuilt) carburetor with the 77.5 and I made it three times as far before the soft seizing which I think is the term for what I’m having happen. Again it started back up and drove on home this time. So...
Bigger main jet is getting ordered, I’m thinking an 85 or 90 and I’m going to mix my fuel with more oil, maybe 30-1 over 40-1.
Yamaha shop told me 25:1 but that’s insane
What if I got a bigger one of these as well?(see photo) current ones a 40 (edited)
> Geoffrey C Wrote:
>... and I’m going to mix my fuel with more oil, maybe 30-1 over 40-1.
I used to run Yamalube 2R at 16:1 in my race bike.
The injection runs rich, could well be 25:1 ratio, my Hobbit suggests 25:1 right on the tank, I ran 32:1 in my QT. (no oil injection)
I’m going to try this 77.5 (seemed like a good spare to order being I didn’t know what I was doing). Tomorrow I’ll up the oil in my fuel.
I’m going to check and see if I can get a cooler plug, what’s the coolest plug(that’s good for a 50cc QT50)that’ll still start and run good?
You can go 40:1 50:1, I just use 32:1 because I have a 4oz bottle. :)
> good?
http://www.strappe.com/plugs.html
Years ago I’d got a new outboard motor and was told to break it in(first full tank) 25:1
So what about this little jet I held up a photo of, I never hear of anyone changing that one....
That's the pilot jet . If the bike idles fine , leave it as is .
Bike idles Just fine.
Jack Rutherford /
No air leaks? Are your seals installed correctly? Leak down test in order?
They sure seem to be installed correctly but I’m going to do a leak down test and see if I’m losing something somewhere.
