78 Sachs Balboa throttle grip
Hi I was wondering if anyone has had the problem of their throttle grip spinning around in circles. I can reach full throttle and still spin past it but the throttle will return to idle after I let off. Any suggestions?
Re: 78 Sachs Balboa throttle grip
Beach Club Nick /
Take it off and look at it to see what's wrong with it. My guess would be your throttle tube is broken in some way. Unless you mean the entire throttle housing rotates in which case you tighten the 1 screw that holds it on.
that or it's just a loose grip and you need new grips
