Re: Sachs 505/1D Timing Marks Not Lining Up
Born to be WillD /
> Jeff Dittenber Wrote:
> Thanks BTBW.
> The key seems to be in good shape. Someone on the facebook group also
> suggested maybe the flywheel is not original to this bike. Seems like a
> logical possibility. Thanks for the heads up on the seal. The weird
> thing about the lacquer is that it is rock hard, which wouldn't be a
> very common trait if it were oil. But, maybe premix gas that had sat in
> there for years and turned?
yea I've seen it too, I think it's just a little bit of gas seeping out steady over time. it may also be part of the case sealer, though I dunno why there. Anyway I've def seen it on plenty of bikes that ran fine. When it gets bad enough to be a problem you know. it'll get to a black splatter visible on back of the stator even.
