Re: Sachs 505/1D Timing Marks Not Lining Up
Born to be WillD /
it's not uncommon for the sachs to slip timing, the woodruff key or the keyway in the flywheel would be visibly marred. But for timing, marks dnt really matter - identify top dead and set the points from that, making your own mark.
the brown goo is usually an indicator of a leaking seal. it may not be that big of a deal, but you may want to replace that crank seal sometime soon
