Re: First time replacing piston rings
Jessie Paull /
> Dirty30 Dillon Wrote:
> > > If you had a stripped stud hole, I bet it's loosened up again.
> > I was thinking about that, but if it was loose shouldn't I be able to
> > find it leaking on that side with the soapy water?
> Are you doing a leakdown test? If youre just spraying water when it
> runs, that won't do anything.
Well it's not running, so I'm just spraying soapy water while someone pedals for me. I've never heard of a leak down test - I'm still learning here, so I'll look into that for sure.
  First time replacing piston ringsTopic by: Jessie Paull Jessie Paull 08/10/20 11:31AM
  Re: First time replacing piston ringsRe: Bob Naske Bob Naske 08/10/20 02:03PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 02:16PM
  Re: First time replacing piston ringsRe: Mike Boyd Mike Boyd 08/10/20 02:34PM
  Re: First time replacing piston ringsRe: P D P D 08/10/20 04:55PM
  Re: First time replacing piston ringsRe: Dirty30 Dillon Dirty30 Dillon 08/10/20 05:42PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 07:23PM
  Re: First time replacing piston ringsRe: Dirty30 Dillon Dirty30 Dillon 08/10/20 08:31PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 10:00PM
  Re: First time replacing piston ringsRe: pat splat pat splat 08/10/20 07:18PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 07:21PM
  Re: First time replacing piston ringsRe: Richard Eberline Richard Eberline 08/10/20 07:44PM
  Re: First time replacing piston ringsRe: P D P D 08/10/20 07:52PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 10:09PM
  Re: First time replacing piston ringsRe: P D P D 08/11/20 07:22AM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/11/20 07:47AM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/15/20 12:17PM
  Re: First time replacing piston ringsRe: Papa _ Papa _ 08/15/20 01:19PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/15/20 02:01PM
