First time replacing piston rings
Jessie Paull /
I recently got these replacement rings from Treats for my Hobbit:
https://www.treatland.tv/OEM-honda-NC50-NA50-PA50-ring-SET-p/oem-ring-set-13010-gf8-306.htm
I had never done this before, but it seemed pretty straight forward:
-I removed the old rings, carefully slid the new ones on
-Put on new base and head gaskets
-Oiled everything up, carefully compressed the rings and slid the cylinder back on
-Swapped the old bolts for studs and torqued them down to spec (the bolts were stripped out or something and wouldn't torque down enough when I first put the cylinder back on)
I felt pretty good about everything, but when I went to start it back up I had NO compression (gauge reads only 25 PSI). I checked for leaks around the cylinder (head and case) by spraying soapy water and didn't find anything.
So I'm thinking that it must be that I didn't install the the piston rings correctly - I did leave out the "helper ring" that came with the set, so I'm hoping that it's. Are the other things I should be checking for when I pull the cylinder back off, though? (edited)
  First time replacing piston ringsTopic by: Jessie Paull Jessie Paull 08/10/20 11:31AM
  Re: First time replacing piston ringsRe: Bob Naske Bob Naske 08/10/20 02:03PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 02:16PM
  Re: First time replacing piston ringsRe: Mike Boyd Mike Boyd 08/10/20 02:34PM
  Re: First time replacing piston ringsRe: P D P D 08/10/20 04:55PM
  Re: First time replacing piston ringsRe: Dirty30 Dillon Dirty30 Dillon 08/10/20 05:42PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 07:23PM
  Re: First time replacing piston ringsRe: Dirty30 Dillon Dirty30 Dillon 08/10/20 08:31PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 10:00PM
  Re: First time replacing piston ringsRe: pat splat pat splat 08/10/20 07:18PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 07:21PM
  Re: First time replacing piston ringsRe: Richard Eberline Richard Eberline 08/10/20 07:44PM
  Re: First time replacing piston ringsRe: P D P D 08/10/20 07:52PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/10/20 10:09PM
  Re: First time replacing piston ringsRe: P D P D 08/11/20 07:22AM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/11/20 07:47AM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/15/20 12:17PM
  Re: First time replacing piston ringsRe: Papa _ Papa _ 08/15/20 01:19PM
  Re: First time replacing piston ringsRe: Jessie Paull Jessie Paull 08/15/20 02:01PM
