Re: Beloved 1984 Trac Clipper still has no power
Probably Fred /
Jetting 101
Best bet is to use your original carburetor and correct jet that produced, the perfect air fuel mixture just because you have a float problem you that have to alleviate doesn’t mean you should pitch the carburetor.
If you shut off the gas and run the bike awhile draining the bowl every time you lafter you run it’s it shut off specially every night the float will not get as waterlogged/gaslogged
There are various other things you could try like coating it so doesn’t get gas logged or post “want to buy” for one on buy+sell.
A round 12mm bing carb with similar jet may jet in the same because it takes same jets as encariwi and available used for practically nothing but going the junk china carburetor route you’ll have no way to know what will work and I’d have nothing to do with anything off that bike considering how bad you got injured
