Re: FA50 Grounding point?
P D /
There should be a ground wire with a ring connector in the headlight 'bucket' .
Loosen one of the bucket mounting bolts and attach the ground , after insuring that spot is shiny clean . Don't want any rust or other type corrosion blocking the ground .
