Re: 1980 Honda Express won't stay running!
Don Ohio /
Okay, I don't know the 80 model has this. There is a hole that can get stopped up in the upper carb where you remove the float bowl. I had this problem once with one I was repairing for a friend.
I finally found this opening and ran a copper wire thru it. Idling problem was solved.
