Re: 1980 Honda Express won't stay running!
Curly T /
if you can get it started but is only runs for 30 seconds, then my guess is that the breather hole on the cap of the fuel tank is clogged, creating negative pressure to the carb. Ttry to clean it out and see if that helps...you can test by loosening the cap to see if that is the issue.
