Re: Moped won't start after thunder storm / rain? here's how to fix
Stephen Keller /
> Mark Kinsler Wrote:
> I've always used WD-40 or the Walmart version of it, which is just their
> general-purpose spray lubricant. Vastly cheaper and equally effective.
> Sometimes my ancient Geo Metro takes exception to a very wet day and
> becomes cranky to start, but a shot of the lube on distributor, ignition
> module, and spark plug wires makes it perk right up. Similarly, my
> various motorbikes have benefited from the same treatment.
> Note that if you ride in the rain and your cylinder gets wet the
> resulting steam will rise therefrom and condense upon any electrical
> components bolted to the frame above the cylinder. My old Suzuki did
> this regularly until I jacketed the ignition coil in some sort of
> raincoat.
Did that in my Baja bug back in the day! :)
