Re: Vespa magneto coils
P D /
> Les B. Wrote:
> how often do the coils just fail ?
Failure can be caused by misuse/mishap .
On their own , not very often .
That is usually dependent on the insulation . If the insulation fails , the coil can be unwound and the wire re-insulated , rewound and the unit would work perfectly .
That was the case with the headlight coil in my 1957 Simplex . The insulation deteriorated and was no longer viable . The coil was just a lump of wire .
I 'peeled' it apart , strand for strand , applied spray paint as insulation to the length of that wire and let that dry . Then wound the wire back into it's original form , to fit over the steel core .
Now the headlight works as nice as if fresh from the factory . ;)
