Rebuilding a Vespa engine not getting fire my question is do all Vespas have a blue external ground wire? Coil supplied with engine has a single red lead to points and an uninsulated lead grounded to coil itself.
Vespa magneto coils
Re: Vespa magneto coils
normally, the ground is in a blue or green insulation, and runs through the brake light circuit.
the typical hardwire is to ground the wire to the coil internally. it should probably be insulated, tho
So I'm thinking I got 2 lighting coils. Or can they interchange?
There are usually 2 coils under the flywheel. One is lights the other is ignition. If you have 3 coils, then you probably have a turn signal bike. The extra coil goes to the battery for the turn signals.
Yes, has to be with that ring terminal on it.
Yup!
I was wondering, the coils seem to be a sturdy part of the ignition. I even had chewed up a bit on a previous rebuild. Picked out scrap,reset , fired up. So I'm wondering, besides the connection wires needing replaced , how often do the coils just fail ?
Failure can be caused by misuse/mishap .
On their own , not very often .
That is usually dependent on the insulation . If the insulation fails , the coil can be unwound and the wire re-insulated , rewound and the unit would work perfectly .
That was the case with the headlight coil in my 1957 Simplex . The insulation deteriorated and was no longer viable . The coil was just a lump of wire .
I 'peeled' it apart , strand for strand , applied spray paint as insulation to the length of that wire and let that dry . Then wound the wire back into it's original form , to fit over the steel core .
Now the headlight works as nice as if fresh from the factory . ;)
Why are your photos so beautiful Cheetah?
Proper lighting go a long way
