Bare bones wiring to get the bike to run
Before I run the entire wiring harness(I’ve got two engines and a couple top ends each), is there a simple two or three wire harness I can wire up that will do the job just to tune and see what, and how I want to set this thing up?
Re: Bare bones wiring to get the bike to run
u just need spark, and.... maybe a throttle.
So hook up a coil and the little cdi black box and fire away?
take a peek at the wiring diagram.
Jack Rutherford /
Black/red from stator to cdi. Orange from cdi to coil. Coil to spark plug. Then you may or may not need to ground black stator wire. And you will need to ground coil but that is normally grounded through its metal bracket on engine.
> bracket on engine.
Thank you! Let’s see if this damn thing runs or not!
No spark. Somethings wrong.
I’m losing it may be time to take some time off.
Until then, if anyone thinks of anything let me know. I shouldn’t need a battery to fire this one off.
Aright. Question. Engines mostly aluminum. Frames off the bike. There’s no battery, is there anything that’s actually a true ground?
Cdi ,HT coil etc must be grounded to case.. check wiring and see if backside of ignition coil also needs to be grounded. Not sure what bike is you are wrenching. Post it's wiring diagram
Jack Rutherford /
wiring diagram qt50
cdi must be grounded too (edited)
> wiring diagram qt50
I will try this again after dinner.
Nothing
Is this the CDI? I only ask because I’m beginning to loose my mind
Kinda looks like it .
We got spark!!!
> Geoffrey C Wrote:
> We got spark!!!
How ?
You know, I’m real good with wiring usually but I enjoy nice clean part, a solder gun, fittings and connectors and this has been a pain in my ass.
By the way the brass tube coming off the petcock broke so I filed it smooth and open. At this point I can probably just run on reserve at al times and be ok heh?
> P D Wrote:
> > Geoffrey C Wrote:
> > We got spark!!!
> How ?
And sure , you can run a straight fuel draw .
So while throwing a little fit and wondering if what I knew was the CDI was the CDI, there was a reason for this and it surfaced today. I’m going through my parts and this little jewel shows up.
ES Control it says on top. I bet this is to aid starting. Do I need this? I don’t like it, seems complex. Anyone qualified to explain to me why I’m wrong and need this or want this please chime in.
Thanks again to all
Jack Rutherford /
You shouldn’t need the control box to start it. In fact, I’ve removed the control box on other qts and they start fine.
In going to rig up an engine for bench testing. In fact, I’ve got 3 of them to test and I don’t feel like swapping the qt ripper off the bike. I’ll let you know.
Let me know, thanks. I think I’m going to go on and rig up a “Tuning harness”.
Aright. I got spark. I put the EBay carb on, didn’t hook throttle or choke up. Will not start.
Why not hook up throttle and choke? Easy enough.
Well, that’s it, it runs and runs I think well.
Jack Rutherford /
