> Jeff Parr Wrote:
> Found it. In a distant galaxy far far away I went to de anza college
> auto tech I started to remember one of the first we were told was never
> use carb cleaner to check for vacuum leaks, It will hit the hot engine
> and vaporize then get sucked in to the carb, always use something that's
> heavier then air so what doesn't get sucked in will fall away. too many
> years and too many brain cells.
Carb cleaner works fine, but only use it on a cold engine. If checking a hot engine, WD40 will work.
