Anyone know where to find them. Blew the case seal behind the magneto. Checked treats but didnt see anything, just gasket sets. Let ya boi know!
Engine seals for puch Allstate
Re: Engine seals for puch Allstate
Most mopeds use off the shelf seals. The Allstate parts manual lists them as "35/17/7" ,but I think "17x35x7" will yield more results. You should replace both at the same time.
Exactly . Seals are generally listed : Inside Diameter x Outside Diameter x thickness/ height .
Got a kit for all the seals. Got a set of gaskets and all new cables and tires. Now i just need a tool box cover for the tank.
Also can anyone direct me to a manual?
Go to the puch section and find the allstate tab. There is a service manual and setup manual there.
https://drive.google.com/drive/folders/1A-VWZahNUwwOMdH_KvlOAo8Pie0a2C6L
