Scrapping sound minerelli v1
I have this scrapping sound coming from the engine or gear box of my minerelli v1. I replaced the starter clutch bearing. Here's 2 videos video 2 you can hear it better. Only happens when I'm slowing down. More so when slowing and turning left.
Re: Scrapping sound minerelli v1
Broken tooth in zee gearbox?
Aaron I don't know that's why I'm asking?
I can't believe nobody has any idea what this noise is!!!
Well I did some maintenance today on it. While I had the rear tire off I cleaned the chain and both sprockets and lubed it with heavy weight gear Oil. Usually I use belray but I was out. Before anyone says shit I've been using gear oil for 40+ yrs on dirt bike and racebikes never had a problem. Started using chain lube and issues started. Anyway lubed and reinstalled the wheel and no more funny noises. (edited)
from the video sounded like center stand flopping around, but after your fix(not oil related), sounds like it was chain slap
Or your wheel was crooked in the dropouts and the chain was rubbin the frame or shocks er somethin
