Anyone have an idea why I am not getting any fuel to the cylinder. I have fuel in the float, all the jets are clear. I tested compression and spark. still no fuel on the plug.
I am going to tear it down and clean it and stuff, but if there are any suggestions let me know. ... oh i guess it might be clogged past the jets.. I just need to clean it I guess but if anyone knows anything else let me know.
94 main 37 idle 60 starter jet in the carb.
70cc a35 parmakit cylinder, with parmakit coil.
I know I have some old reeds in there, that has a little chip in it. going to switch that out with malossi reeds.
Someone has had to have had this problem before. otherwise ill let you know when I get it fixed. or ill end up trading. this is not the right carb anyways, I wish it had the idle screw facing the other way. if anyone has a 19mm carb they want to trade let me know.
Thanks
