Re: Sachs 504/1A Engine - Piston Seized
Mark Kinsler /
I would probably try the following:
>borrow another bike, or some other engine, or temporarily borrow the spark lighter from a gas grill. The idea is to be able to spark the stuck engine's spark plug.
>remove stuck engine's spark plug and clean it if necessary.
>spray in some starting fluid of the ether variety and let some of it evaporate out (some air has to be present in the combustion chamber for the stuff to burn)
>replace spark plug
>connect the spark plug wire from one of the other engines or the spark lighter to your stuck engine's spark plug
>fire the stuck engine's spark plug.
Repeat if necessary. It's not likely to cause damage, but observe reasonable safety precautions.
  Sachs 504/1A Engine - Piston SeizedTopic by: Sean Wozniak Sean Wozniak 07/24/20 04:05PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Jay Rivett Jay Rivett 07/24/20 05:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/24/20 06:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/25/20 12:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Aaron Blair Aaron Blair 07/25/20 12:53PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Papa _ Papa _ 07/25/20 01:44PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/26/20 05:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/27/20 05:25AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/27/20 11:58AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/28/20 05:33PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/28/20 07:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/29/20 01:36PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: pat splat pat splat 07/31/20 03:24AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/31/20 01:38PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/31/20 03:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/31/20 07:22PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Saabsonettguy . Saabsonettguy . 07/31/20 08:26AM
