Re: Sachs 504/1A Engine - Piston Seized
Born to be WillD /
I thought I replied
things I've had success with:
1) put a lot of penetrating oil I. spray in the plug hole, through the intake, through the exhaust, and under the piston (pull it out as far as you can to spray from the bottom too
2) twist it. with the jug pulled off the studs, sometimes twisting gets more torque than yanking it directly off. don't go so hard you bend the crank, but that's not likely unless you're hulking it like a maniac
3) if all above fails, put the jug back on and use an impact driver on the flywheel nut (tightening). that impact should transfer to the piston and loosen it up a bit, allowing 1 & 2 aboev more chance of success. repeat in series it'll work more fluid in and work the piston loose.
  Sachs 504/1A Engine - Piston SeizedTopic by: Sean Wozniak Sean Wozniak 07/24/20 04:05PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Jay Rivett Jay Rivett 07/24/20 05:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/24/20 06:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/25/20 12:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Aaron Blair Aaron Blair 07/25/20 12:53PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Papa _ Papa _ 07/25/20 01:44PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/26/20 05:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/27/20 05:25AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/27/20 11:58AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/28/20 05:33PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/28/20 07:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/29/20 01:36PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: pat splat pat splat 07/31/20 03:24AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/31/20 01:38PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/31/20 03:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/31/20 07:22PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Saabsonettguy . Saabsonettguy . 07/31/20 08:26AM
