Re: Sachs 504/1A Engine - Piston Seized
Mark Kinsler /
> k blum Wrote:
> ok the grease gun comment got me thinking....you could buy a loaf of
> bread and shove a ton down in there till its full and just keep pounding
> with a dowel and filling till the crank starts moving....idk worth a
> shot last resort maybe
Bread is sort of compressible, however. Peanut butter would be more suitable in that regard, and I've heard of bananas being used as a hydraulic medium as well. In this case I'd suggest a leak-down adapter made with spark plug threads on one end and an air valve on the other (you could likely make one) would serve. For grease, you'd weld a bit of pipe onto an empty spark plug shell (the metal part) and to the pipe you'd add a 'zerk' pressure fitting that'll fit the grease gun.
But probably just steady pressure on the piston itself would do the job. One place you might find suggestions is on an aircraft maintenance site, for airplane engines are often made with 'jugs,' or removable cylinders with integrated heads.
I didn't know there were any mopeds so constructed.
Mark Kinsler
  Sachs 504/1A Engine - Piston SeizedTopic by: Sean Wozniak Sean Wozniak 07/24/20 04:05PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Jay Rivett Jay Rivett 07/24/20 05:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/24/20 06:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/25/20 12:06PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Aaron Blair Aaron Blair 07/25/20 12:53PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Papa _ Papa _ 07/25/20 01:44PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/26/20 05:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/27/20 05:25AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/27/20 11:58AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: k blum k blum 07/28/20 05:33PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/28/20 07:49PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/29/20 01:36PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: pat splat pat splat 07/31/20 03:24AM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Sean Wozniak Sean Wozniak 07/31/20 01:38PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Born to be WillD Born to be WillD 07/31/20 03:21PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Mark Kinsler Mark Kinsler 07/31/20 07:22PM
  Re: Sachs 504/1A Engine - Piston SeizedRe: Saabsonettguy . Saabsonettguy . 07/31/20 08:26AM
